Transmission Depression
733
Hunter 30 Vero Beach
I was out this last week and my transmission went out on my 1983 H30. The rear seal gave out and the transmission lost all fluid. I need to find a replacement transmission (preferably a rebuilt) Where should I start? I figured that as long as I have the whole thing apart, I would replace the motor mounts (the cause of the failed transmission), cutlass bearing, and stuffing box. I'm planning on putting a dripless seal and having the shaft checked to see if it's straight. I might also add a three blade prop if it fits in the budget.Any thoughts to which brand of dripless seal? Prop?
W
Wayne Estabrooks
PSS Shaft Seal and Michigan Wheel
Sorry to hear about the loss of your transmission. As for dripless shaft seal, I have had a PSS Shaft seal for several years now and I like it. Lots of archive information here in HOW about it also. As for a new 3 blade prop, lots of archive info here about that also. For fixed blade props I hear Michigan Wheel is great. see www.miwheel.com
Don
Go for a coupling
When you get your PSS dripless seal go for a flexilble shaft coupling as well. It helps reduce the vibration and can also prevent transmission damage in some cases.
Mar 20, 2004
1,746
flexible coupling
PYI sells a good one-we put it on our 356 and it made a huge improvement, only 1.5" thick so it fits between our transmission and flange
