Transducer Replacement
23
Catalina 30 Portsmouth, VA
So today, I bit the bullet and started work in earnest on replacing the transducer. The old one was stuck. Stuck hard, but we worked through that.
It looks like the previous (probably original) was installed in a wooden spacing plug to level it out, with a rediculous amount of adhesive to seal it in. At first try, I disconnected the nut and whacked it with a hammer.
I have never heard so clearly the silent noise of inanimate laughter.
I then proceeded to chip away around the edge of the 'ducer, the better to pry it away. I used a putty knife, as had been suggested on these forums. I then took another whack with the hammer.
The laughter turned to snickering.
On the recommendation of another guy at my boatyard, I grabbed a set of vice grips, and rotated the 'ducer about 180 degrees, then had my wife pound on the 'ducer while I pried on it from below. After a few moments, the stupid thing was dangling by its cable.
Now, I just need to figure out a way to enlarge the hole so my new 'ducer will fit. It is just *slightly* bigger. I'm thinking dremel, since the hole is a bit big for a reamer, and a hole saw would be a bit inaccurate with such a huge pilot hole. If anyone has any thoughts, I'd love to hear them.
Mar 23, 2010
23
...and I just realized I managed to somehow post this in the Hunter forum, not the Catalina. Sorry.
Carry on, citizens.
