i want to mount a depth sounder (display has two docks (one for cabin, one for cockpit))the transducer is a skimmer type (low drag, not through the hull though.)i would like to mount the transducer forward of the keel, so i can see what i'm about to hit + not what i just hit.does anyone have experience / thoughts on the idea of: running the cable over the transom, then forward along the bottom, parralel to the keel/hull joint, then attatching it a foor or so forward of the keel. cable has to travel aft due to way cable comes out of transducer.any ideas on what adhesive would be best? i plan to use marine goop to hold the cable tight to the hull + transom.
