Hello All!
I am preparing to install an Airmar B744V thru-hull transducer on my 78 , shallow draft, H30. Unfortunately, I am having a difficult time finding a location forward of the keel with suitable access from the inside. I have found two no longer used, old thru-hull transducers along side the keel. One is a good 26" from the keel. I would like to knock this one out and replace it with the new transducer.Would 26" be sufficient distance from the keel to allow mounting beside the keel?
Thanks in advance!
Thanks in advance!
