Re: why
My marina neighbor has a 30 ft Hunter and told me he has done it many times (over a 100). Although I do not plan to do it I am simply researching all the options in the event I need to inspect or perform maintenance on it while in the water. The water is pretty in the San Francisco bay in the event I had to get into to inspect the knot metter paddle wheel, etc. even with my dry suit. When I purchased the boat last November the knot meter did not work but the pull out for a survey revealed a barnacle attached itself to the paddle wheel. I knocked it off before the boat was put back into the water and it has worked fine ever since. This is my first sailboat and the owner's manual does not have such information in it nor have I found the fitting on the boat.
