Tranny removal with boat in water?
Mitch35.5
Does anyone know if a tranny can be removed without hauling out? Or, can you get the required shaft space to get trans splines to clear engine? Seems like pulling the trans is fairly basic but I have no experience with letting the shaft slide back a little. Is this ok to do?
Oct 29, 2005
2,363
shaft should not slide back. packing gland should be tight enough to hold. also shaft flange must not be remove for just incase.
Feb 6, 1998
11,713
Depends on.. boat, sapce, tranny, configuration & shaft seal.. Some transmissions can't be removed in water without sliding the engine forward..
What is the boat and what is the engine/trans/config..
