Trailing Height
L
Larry Tunison
My 21' has a factory trailer. Does anyone know what the trailing height is for traveling - undrpasses, etc. This is the first time I have towed her anywhere. Any advice would be appreciated. Thanks, One year owner, Larry
Mar 28, 2006
50
Macgregor 21 Cow Canyon Colorado
Depending upon how your mast is stowed, unless you wish to trailer with the mast up - I see no issues. My 21 follows my Ford van, and is lower than the van. Get some weight on the tongue, and nose her down just a bit - Unless you have an undersided tow vehicle. Mine tows like a dream.
Macgregor 21 Clinton, NJ
No problem with any bridges
You won't have any problems with height unless you're using an exceptionally tall mast crutch on the stern. I also use the original ancient trailer. I secure my mast to the pulpit in front and the mast crutch is only about a foot higher than the cabin in the rear. This puts the trailering height at about a foot higher than my mini-van. You won't fit through any fast-food overhangs (as if anyone had enough room to turn), but I haven't seen any bridges that even come close to that low. Overhanging trees in a residential area though....
