Just a few thoughts and words of advice to those trailering their
boats. If you have an automatic transmission make sure you have an
additional trans cooler installed to save your trans from overheating
and burning out. Most of the people who are trailering their boats
have only a two wheel drive vehicle and must be extra carefull if and
when they use a ramp to unload their boats, as the weight of the
trailer and boat exceeds the towing vehicle by far. It could be
pulled into the water!! A four wheel towing vehicle is almost a must
when pulling the boat and trailer from the water up the ramp as the
rear wheels will almost certainly be immersed in the water at the
ramp and will slip. On a ramp you are not pulling a rolling load but
some of the actual weight of the boat and trailer due to the incline.
Some people say "bigger is not always better" but in this case a
bigger engine and vehicle loading applies. I use a Ford F350 4X4
diesel with a stick shift to get my extended tongue trailer and boat
out of the water, and never had any problems putting the rig in or
out. Walt
out. Walt
