retrieving 26s classic onto trailer
We have a 26s "classic", which doesn't have quite the windage of the X, but also has less motor power. My crew doesn't like to get wet, so tossing a bow line to someone near the trailer who could help center the boat isn't an option. Life is easier if you have crew who don't mind getting wet by standing alongside the trailer. I try to make an approach that allows me to chicken out and try again if winds get to squirrely. Also, we have had our MacGregor stock trailer modified with two bunk boards on each side of the boat and a v-bunk below the bow, which help center to boat if it approaches the trailer at an angle. On my approach, I already have the centerboard up and the rudder partway up - enough up so it won't catch in the bottom if the trailer has to back up but down enough so I can use rudder, motor, or both for steering. Trying to outguess wind puffs, crabbing into the wind, and then straightening up at the last moment can be either a game or a bit nerve-wracking, depending upon just how bad winds are. Picking a less-crowded time to retrieve helps.
