Trailering the Vega
Oct 30, 2019
2
I am a complete rookie to sailing. I just bought a '72 Vega. I assume the boat is trailerable, but stowing the mast looks a bit more complicated. I assume it's all possible, right? Does anybody trailer this boat regularly? And, I would appreciate any advice I can get, thanks....Craig
Apr 12, 2016
102
Hi Craig - Yes, the Vega is trailerable. I'm actually leaving Florida tomorrow morning (July 4th) to go pick up our "new" Vega in Massachusetts and haul it 1800 miles back. It will be the biggest boat I've ever towed, but I'm pretty confident. We had a brand new trailer built for it (by Sail Trailers, in Columbus, GA) and I traded in my old Tacoma for a 2016 Tundra to get the necessary towing capacity.I'm working on a hinged mast plate which will enable us to step the mast without the (expensive) aid of a crane.I've trailered a Catalina 22 for years, but this will admittedly be a whole new experience. I can probably give you a LOT more details when we get back! LOL
Feb 13, 2010
528
Wow! thank you very much! That's encouraging. I have to be able to handle it all myself. Also, realized with solo sailing, I should install mast steps, to be able to get up to top of mast, for "snafu" problems.
Feb 13, 2010
528
Congrats on your new vega as well! This is my first sail boat. But I'm so tiredof upgrading toys, I wanted a bluewater boat, right outa the gates.
n4lbl
Oct 7, 2008
307
We bought our Vega on the Chesapeake and trailered it from there to Colorado on a Triad Trailer. We towed it with a ¾ ton gas pickup truck. We carried the mast on two pillories (can\'t think of the nautical name) tied down on deck.I\'m tired of starting sentences with "we".Remember, the boat empty weighs nearly 5,100 pounds, the trailer (in our case) weighs 1,600 pounds, and then there is "stuff". Make sure that you can safely tow it all. Alan
Mar 26, 2014
14
I\'ve trailered my Vega from Halifax to Rivière-du-Loup (some 900 km or 500 miles) with a F150 as towing truck. Had no problem at all.Cheers!Jean-François RacineLe 3 juil. 2016 à 09:46, craig hanson a62craig@... [AlbinVega] <AlbinVega@yahoogroups.com> a écrit :
Oct 30, 2019
16
Ha I just got mine as well. 16 days ago! Since then she has been sanded to the glass competely leveled. Installed all new wiring, all LED lighting, she gets paint Tuesday hopefully splash Friday! Man they are beautiful, but after doing all of this I feel like a child waiting for Christmas.
On the hard
Feb 13, 2010
528
Thank you. What has me puzzled is, getting the mast down. The procedures, and the hardware needed to get the mast down without damaging your boat. Thanks for your help.
Feb 13, 2010
528
That's such good news, hearing about your Vega! What a obsession!!! I should go to meetings for this! It has surpassed all sensability.... lol...but, there's worse things..
Feb 6, 2011
253
If you need help, let me know . I bought my first vega from a nice guy named John a year or so ago . It's easily trailerable and not hard to sail at all . It is a heavy boat . Sent from my iPhone
Gazuum
Oct 23, 2010
67
Pearson P365K Port Angeles
If it doesn't have a tabernacle type device (nothing on the
base where it meets the deck) it will have to be lifted off.
If it has a tabernacle, search youtube for lots of videos.
A mast lifting device I saw at one marina was a telephone pole
with a yard arm extending out. A simple boat trailer winch was
attached to the pole and the cable going up the pole and out the
yard and hanging down. Hook the cable to the mast, disconnect the
standing rigging and lower the mast onto the cabin top.
Gordon
On 7/4/2016 9:20 AM, craig hanson
a62craig@... [AlbinVega] wrote:
Feb 13, 2010
528
Okay.....thanks for the link. I'll check it out. Can you give me a price you paid for your trailer?
Feb 6, 2011
253
Are you planning on keeping it trailered and stepping the mast every time you want to go sailing ?Sent from my iPhone
n4lbl
Oct 7, 2008
307
In '12 it cost in the low $5K range. I chose to skip the equipment for self-launching and will rely on travel-lifts. Using a travel-lift also solves the issue of stepping and unstepping the mast.Alan
Jan 28, 2001
694
Hi Robert, We trailered our Vega back from Mexico a few years ago. All in all I thought the tow could have went better. I think I have to much weight on the hitch. My frame sits on a carriage which supports two axles and can be moved by unbolting six 3/4" nuts. If it isn't to much trouble would you measure the distance from you ball receiver to the front axle and the distance from the front axle to the rear axle? I'm presuming you have a 2 axle trailer. We're hoping to tow her down to San Francisco later this summer. Thanks, Walt S/V Lyric #120From: AlbinVega@yahoogroups.comTo: AlbinVega@yahoogroups.comDate: Mon, 4 Jul 2016 13:26:04 -0500Subject: Re: [AlbinVega] Re: Trailering the Vega
Jan 28, 2001
694
I'm kind of assuming that this boat hasn't been trailered before. You are also going to have to consider mast head wiring and VHF cable. These need to have a junction where they can be disconnected. Mine go through a deck fitting at the base of the mast and into the head. Junction box for the wires and a connector for the cable is mounted on the bulkhead by the head.From: AlbinVega@yahoogroups.comTo: AlbinVega@yahoogroups.comDate: Sun, 3 Jul 2016 23:03:47 -0700Subject: Re: [AlbinVega] Re: Trailering the Vega
On the hard
