My C-22 Trailering Experience
We trailered both our Capri-18 and our C-22 MK-II version,(both wing keels, both with the factory mast raising systems). We had setting up the Capri-18 down to about 35 minutes, but we've gotten a bit lazy now because we joined a local yacht club with dry storeage and a crane. The boat is kept fully rigged on the trailer, and all we have to do is disconnect the rear stay and swing the boom out of the way to connect the lifting harness to the crane,(they even have electric mules to move the boat from the storage spot to the crane). We can be in the water within 10-15 minutes after we arrive at the club. We still trailer our C-22 several times a year, and set-up probably runs 45 minutes to an hour, we just plan accordingly, and don't rush the process. That's another nice thing about having the boat dry stored at the yacht club. When trailering, it was a two day commitment. I wouldn't take the boat out for just the day. But it's no big deal now to take the boat our for the afternoon. I must say, raising the mast on our C-22 is much easier than the Capri-18. I believe this is because the gin pole is so much longer, because the distance from the mast to the bow is greater on the C-22 than the Capri-18. Another bit of time during the set-up with our C-22 is due to the trailer lighting wiring. I've made the trailer wiring into a removeable harness so I don't have to worry about dunking the wiring and lights in salt water anymore. Works pretty slick, and avoids trailer lighting issues, but takes 5-10 minutes to remove, or install. Another trick we learned is using two-sided velcro strapping for securing the stays, and trailer wiring. Holds strong and quick to remove. Years ago when we had our original C-22, I man-handled the task of mast raising. I was a lot younger back then, and I still hated the task. I must say, the factory mast raising system is well worth the expense!
Don
