Not that Bad
Anthony, We bought our 25.5 shoal draft with out a trailor but had to buy one. So we bought a new one like Dick says ther hard to find. We pulled ours 350 miles each way to Lake Michigan two years in a row. A buddy did the same with his and some other friends just bought a new trailor for there 25.5. We used our Jeep Cheroke with the High Output 6 and it was just fine, no problem. It is a big load and the boat on the trailor is big but with brakes on the trailor it was not that bad. We all did have to install a bow eye you will need to cut out some fiberglass in the bow on the inside liner to get to the hull but still not that tough. The bow eye is just to hold the bow down on the trailor you must float the boat on and off it's just to big to try to pull it on the trailor with the bow eye. Also you need a tounge extension for the trailor. Getting the boat on and off depends all on the ramp. You need a pretty flat ramp, all in all it was not that difficult, it's just big. The boat on the trailor were balenced and we were able to drive 65 mph on the highway with know problem. Its sit's way up there and you might need to keep an eye on over pass height, I think we were around 11 feet to the top of the mast. Owning the trailor was a all win for us. We were able to travel with the boat to Lake Mi. and Lake Erie and not need to depend on others to get in and out of the water. It also saved on winter storage and I was able to bring it home and work on it. I have sold the boat and trailor and now have a Tripp 26 it's a full blown rocket with sails, not much down below nice bunks but that is about it. You seem to forget about the down below stuff when your doing 15 knots on a Spinnaker Reach. Having to not depend on a crane and a yard was my reason for not buying a bigger boat like a Hnter 28.5 or a J 30. After being so used to doing it all my self and from a cost factor buing a boat that I can do all myself only made sence to me. Cliff
