trailering a c-22/1974
tod
I was given this sailboat recently & know absolutely nothing about sailing!The boat didn't come w/ a trailer & is currently in salt water.I want to get it out so i can clean it up.I'm having a hard time finding a used trailer.My question is this - can i use a regular trailer or do i need something special to accomodate the retractable keel? Thanks!
Ken
Jun 1, 2004
1,182
Catalina 22 P. P. Y. C.
trailer
Lots of people convert powerboat trailers, there is a fellow sailor in GA. that builds trailers for the C22 converting a trailer isn't hard if you have the tools to pay someone though would cost. Labor intense. http://home.att.net/~sail-trailers/
Bilbo
Aug 29, 2005
1,265
Catalina 22 Ohio
Trailer
Sometimes you can find a used trailer that fits. On these forums, E bay or http://www.sailboatowners.com/forums/index.htm?fno=20 I did find a used one and consider myself lucky. There is a trailer Co in Georgia and one in Eastern Pa. that makes them specifically for this boat in the $1500 range. Generally, the trailers out there have long rails (Bunks) to support the hull. Then the winched up keel is lowered a bit onto a support or roller. This takes a bit of the weight off the keel setup and the hull supports. It is good to have some sort of setup to line up the stern of the boat onto the trailer like hull guides or a keel guide. When you pull out the boat,check the keel condition for rust, the condition of the keel cable for fraying and pivot assembly for wear. Very important. Yuo don't want the cable to break or to have the keel drop off the boat. I am into this right now. There are several sites on the net for Catalina 22 info., technical data and maintenance of boats and trailer. Such as the Catalina 22 National Association. Catalina Direct. Chip Ford 's outstanding site. -for starters. ~Bilbo
