trailering a 322
18
Oday 322 Falmouth Cornwall U.K.
Does anyone know if it is possible to pull a 322 on a trailer with a powerful car? There was one for sale on Yachtworld that was advertised as 'having its own trailer' so thought I'd ask you all. We have moved ours on a low loader but is so expensive.
Many thanks
Nov 13, 2011
163
Oday 23 New River Az
"powerful car", not a chance, you are into 3/4 ton truck territory here.
BarryL
May 21, 2004
1,058
Hey,
As mentioned, there is no way you are going to move a 322 with a car. The boat and trailer will weigh well over 10,000 lbs. IMHO, that is too much for a pick up truck (well maybe a crew cab dually) and you really need a SERIOUS tow vehicle.
Barry
Jun 2, 2004
1,941
Oday Day Sailer Wareham, MA
A 322 weighs at least 10,250# dry, no gear, no extras, just the boat as she came out of the factory. Add weight of the trailer and normal sailing gear and you are well into the realm of a "Big Rig" or at least heavy-duty pick-up truck. Plus, not many ramps are really designed to easily launch/haul a sailboat drawing 4'2" off a standard trailer (Hydraulic boat-hauler trailer...... sure, made for that type of ramps) and even if you COULD find a suitable ramp, stepping/unstepping the mast will require a crane or else some fancy modifications.
Yes, I suppose you could, with the right setup, become your own "boatyard" and haul a 322 out in the Fall, store her at home, then launch in the Spring...... but it will be a big job!
Nov 3, 2010
564
Oday 39 Lake mills WI
The internet has allowed anyone to contract haulers of all types for any load. There are many guys out there with heavy duty pick-up trucks hauling just about everything. Start with Uship.com
The key is to have open dates and not be in a rush. Uship has allowed many small time single truck (HD pickups with trailers) guys to get into the business and has driven prices way down.
Give it a try.
May 29, 2007
18
Hi Panta Rei, thanks for that idea. We would like to take our 322 from the UK to the Ionian in Greece, but it's a long sail! The quotes we have had to take her overland so far are between $8000 and $19,500 so are really out of the question. I asked about the trailer with a view to taking her ourselves but will have a look online as you suggested.
