Trailering a 25???
A
ALLEN
I am thinking about buying a larger boat. i want to keep it on a trailer. I keep my current boat at my house. easy to maintain, and go to different areas. my question is. how dificult is it to raise and lower mast on the oday 25. I can raise the mast on my current boat by myself. How about towing and launching
Ben Allen
The Bigger The Better ...... Well Maybe
Allen, I have trailered, sailed and launched a Previously owned Catalina 25, and my current O'Day 26 singlehanded. With the right setup, it can be done safely by yourself, but is a lot easier with two or more. This is not the kind of boat you want to haul down to the launch, rig, daysail, then bring back home, all in one day. When I haul mine down to the Gulf, it is for at least 4 days before returing home. When considering towing something of this size, your tow vehicle has to be up to snuff. Unless you are just bring it home a couple of blocks, you will most likely need V8 engine, transmission cooler, heavier suspension, and brakes that are in great condition. Your trailer will need to be equipped with brakes also. OK, so far you have successfully be able to get your boat to the coast, raise the mast and get it all rigged out, and now you are ready to launch. Getting the boat off the trailer if pretty easy, use reverse and hit the brakes, works every time. Retriving the boat will require either, (1) A tongue extension, (2) extende the trailer into the water with a tow strap. One of these two methodes will be needed to get the trailer in deep enough water without sinking the tow vehicle. I have made several trips to the coast (200 miles each way) over the last 2 years. It's not that hard to do, just don't get in a hurry, keep the maintenance up on your vehicle and trailer, and watch out from large trucks passing you. With this size boat, you can easily spend two weeks or longer on your boat and enjoy new territories. E-Mail me off line if you have any other questions: benallen1@mindspring.com Good luck with your choice. Ben Allen Montgomery, AL "Latte Dah" O'Day 26
Justin - O'day Owners' Web
25
Allen - I would only echo what Ben said and really emphasize the tow vehicle reommendation. You really do need a big car or truck to pull something in this class. Justin - O'day Owners' Web
