Trailer...
Oct 31, 2019
14
Does anyone have a road ready trailer that they would like to rent?
I'm exploring my sailing options for the summer.
Feb 12, 2008
337
Our sail club is selling our old committee boat that is on a tandem axle trailer, that could probably be converted to a Vega trailer. It is a 70's Bayliner Saratoga. I think they want around $3000 for the boat and trailer, probably won't sell the trailer seperately. It's in Colorado. -Tim
n4lbl
Oct 7, 2008
307
Just in case you aren't aware: You will likely need a so-called "weight
distributing hitch". My 3/4 ton pickup can't trail more than 6,000 lbs.
without one. Also the Vega dry and empty plus a 1,600 lb. trailer (what
the documentation says mine weighs) is ~6,700 lbs. which is marginal for
some 1/2 ton trucks. Remember too that you will likely want to carry
'stuff' too.
Alan
On Wed, Mar 27, 2013 at 9:12 AM, markhern@...
hern_104@...wrote:
Jan 19, 2011
3
I have a Vega trailer. The trailer itself is road ready, I pulled it 60 miles no problem and it tracked well. It is not in the shape to pull a boat right now though; the brakes and lights would need work.
I had to throw on some portable trailer lights, and run it without working brakes. It has all new tires (4) about 6 months ago. The trailer is registered but not used to pull a Vega on the road for at least 5 years
Your welcome to use it rent free just for returning it road ready.
Ray
raybean123@...
Feb 5, 2007
3
Hi,
If you have checked all the skin fittings, the first item I would suspect is the drain plug in the bilge sump. It is merely a bronze fitting glassed into the laminate. After that I would check for leakage around the bronze rudder tube and the shaft log both of which are laminated into the hull. The bond between these fittings and the surrounding glass can let go and leak water start leaking inside the boat. None are that hard to repair but they are best done with the boat in dry dock.
Lee Taylor, Marine Surveyor
Taylor Marine Surveying & Consulting, LLC
963-C Woodland Estates Ave
Ruskin, FL 33570
Telephone: 813-500-9811
727-490-9811
International Calls +1
Email: taylormarinesurveying@...
info@...
Website: www.taylormarinesurveying.com ®
The information contained in this electronic correspondence is legally privileged confidential information intended only for the use of the individual or entity named above. If the reader of this message is not the intended recipient, you are hereby notified that any dissemination, distribution or copy of this message is strictly prohibited. If you have received this message in error, please notify the sender by replying to this message and then delete it from your system.
