John Scharer
Just got back from a week long trip to the Cheasapeake Bay and wanted to share our trailer problem with everyone. After putting Zinfandel in the water in Deale, Maryland, when I pulled the trailer back out of the water the bottom centerboard trailer bunks which the centerboard sit on were no longer attached to the trailer. I was able to retreive one of the boards but after wading in the water and feeling around with a pole I could not find the other one. When I inspected the one board I found out what the problem was, boards were screwed into the underside of the trailer not bolted to it. The upper bunks are bolted. Needless to say I had to find another board, put astro turf carpet on and bolt them to the trailer with carriage bolts. Luckily, my brother in-law came to the rescue and helped us out. I suggest you check your trailer boards before you set out on your next adventure.
