Question for all MacGregor 26 sailors that tow their boats. Especialy the 26C towers.Do you have Surge Brakes On Your Trailer? Are they well maintained and working? Would you get Surge Brakes again? For those that do not have Surge Brakes, do you feel that this is a problem?If you respond, please say which MacGregor 26 you have.The reason I am asking is this. I bought my 1993 26S and trailer last August and towed it home with my 3/4 Ton PU. I have been going through all systems on boat making sure they work, and upgrading some of them. This weekend I started on the trailer. The first thing I found is that the surge brake system had no fluid and rust in master cylinder. It is frozen. This means that I will replace eveything including the wheel cylinders, fluid lines, and complet coupler. Haven't check brake linings yet.However, not sure if I really need surge brakes with my Heavy Duty Extra GVW 3/4 Ton PU. It is good for 8600# GVW.Thanks for Input,Chuck
