Trailer Suggestions Please Help
23
Hunter 26 Lake Lanier, GA
Just bought a 1996 Hunter 26 and would appreciate advice on where to buy a trailer. Should I buy one from Hunter? Should I have one custom made? Please advise.
Aug 11, 2006
1,446
Hunter H260 Traverse City
H26 Trailer
H 26 Trailer There was a lot of discussion on this very subject recently. Suggest you browse the archives. Bottom Line: If you've seen this trailer you quickly realize that it is somewhat different from most trailers. You can probably find one that you can modify for your boat, but you'll be happier contacting Hunter and getting one that is designed for your boat. Try Hunter customer service (800) 771-5556 customerservice@huntermarine.com Also, there has been lots of discussion regarding the proper towing vehicle. This boat/trailer combination will weigh over 5,000lbs so make sure your vehicle can safely tow it and is properly equipped.
