Steve, that's us
The original owner put the axle together. It was one of the major selling points for us. Like I said, as well you know, some neglect their trailers badly. Having piece of mind on the road paramount. The ease in changing the grease in the axle creates more sailing time. There is a zirk fitting on the outside of hub so, you pump in new grease, wipe off the old, your done. Much better than taking off the entire hub. Remember grease breaks down with each immersion, especially salt water. Primarily the axle instalation doesn't take away from the stuctural strength. It also takes away from that "bounciness" when working on the boat, on the trailer. If you see us on the lake, usually Saturdays, stop and say Hello. D&D Brown "Splash" '92 Mac 26s
