Bob
They say a wise man learns from the mistakes of others, and I've heard enough horror stories from other folks to check my wheel bearings and make sure they are in good shape and well-lubed. If you don't check yours, put a cold chisel and a two pound hammer in your tool box and prepare to find out how hard the bearing races are while you are trying to cut them off the spindles to which they have become welded while spinning dry at 55 mph. This will usually be in the rain in an inconvenient location. An absolutely critical part of your trailer is the grease seal that keeps the water out of the inside lip of the hub - if it's not in good shape, you deserve whatever happens next. After a launching or take-out make sure you pull the trailer down the road at least half a mile. If the bearings have taken in water, this will cook most of it out. Even more critical is the condition of the spring shackle bolts - they are inconvenient to check, so most folks put it off. Jack up the trailer (with the boat off, otherwise you can bend the frame), pull the bolts and check them. If they look pretty good, clean, lube, and replace them. If they look shakey, think about what a pain it would be to have one let go at 60 in traffic (or not in traffic, for that matter.) Remember, the boat won't sail if you can't get it in the water. MAINTAIN THAT TRAILER.
