Length of trailer and other considerations
There are other issues besides the ability of the car to pull the trailer. Stopping it is one of them. Also, the length of the trailer is something else to consider. A 26 foot boat, even without the ballast, is approx 2x the length of your car, then factor in the extra distance of the trailer tongue etc. Having had a Jeep Wrangler and pulling an 18 foot trailer with a 13 foot Whaler (well below the rated trailer weight of the car) was a hairy experience when I finally realized that "odd sensation" I was experiencing was due to the fact that the trailer was about 2x the length of my car. Just a big lever back there stuck onto a bobtail car. In the case of the Mac26, if you go for it and put the 50 HP 4 stroke on the back of the boat, then you've pretty much fully loaded the back end of the lever haven't you.Other considerations - the transmission will get hot, the brakes will heat a lot, and fade as they heat up. Your rear suspension may sag and the nose of the car will lift up, this kills your traction and control of the front (driving) wheels of the car.Then again, if all you are doing is taking the boat "down the street" to launch it, the car may be fine.Oh yeah, one last consideration, the Camry is a front wheel drive car, imagine trying to get the boat out of the water, up a ramp, after the trailer wheels have dropped off the lip at the end of the ramp. I've seen more than one front wheel drive car go for a back-fender dunk when this happens. The lip acts like a giant wheel chock and the front tires just spin as the car slowly settles backwards into the water.Spend some time talking to folks who trailer boats, go down to a launch ramp and watch the activity. It can be very enlightening.Auto Warranty - check to see that happens to your warranty when you hang a trailer hitch on the car. This is a dead giveaway to the dealer when you take the car in to ask about the tranny problems.Just my $.02.....Geofs/v Day-O
