Towing
Steward:I also would caution with towing with a mid-size car but it can be done. I also use a Ford Ranger 4X4 and consider that to be the smallest that should be considered. You have little room for error or surprises.Remember, when you pull out of the water, the boat will be 4000 to 4500 pounds unless you dump the ballast before docking, which you can do on a 26X. Depending on the ramp, that can still be a real pull at best and if a tailer wheel drops off the end of the ramp, you could have a problem. A slick steep ramp can be a challenge.It also depends on the trips you anticipate. If you are doing minimum distance on flat land, perhaps it would work. You have some great sailing over in Gulfport on east, even if that is not that far,you may find yourself making it frequently.Good Luck
