I
It's DnA
I recently aquired an '87 25 MacGregor. The trailer rails needed new carpet, but before I did this I had a couple of questions. I've attached a photo to help illustrate my concerns.First, the front of the rails seem to have created a 'dimple' in the hull on either side. Is this common and is the boat designed this way. Would replacing the current rails with ones 2 feet longer be appropriate?Second, the bottom of the hull rests directly on the wooden block on the front trailer cross-member. On two boats that I owned previously the front end of the hull "v" didn't rest on the trailer. The rails supported the weight. Again, is this setup correct, or should I raise the rails to get the "v" off the trailer. I appreciate your feedback.Dan
