I could really use some help with some comprehensive pics of the Magic Tilt trailer that came out with the 1981 H22. From what I can discern, this same trailer was used for later years and mighthave been the same trailer for th 23 & 23.5. I have a tandem axle trailer that is not original to the boat and I want to install the second set of bunks that are located closer to the swing keel. If you have one of these trailers, I would be forever in your debt if you could provide me with several detailed pics. I want to make sure I will be installing the bunks in the correct locations. Thank you. -Herv
