Here is the Winch on the trailer and the coupler in a separate shot.
Problem1
The winch handle was lost as I drove away from the ramp and left it attached. (stupid).
Problem 2
Last season it was extremely difficult to remove the ball from the coupler.
The UPPER LEVER HANDLE in the winch photo is moveable but the bolt below it seems frozen.
I shot a photo looking up into the ball coupler also. The spring seen in this shot appears to be connected to the "frozen" bolt.
I think the upper lever handle (on the ball coupler end of the mechanism) slides up and allows the lower coupler to move upward to receive the ball?
There is a lever on the top of the assembly(it has a rusty wire through it)
Would you know what procedure to follow? How to unjam the lower bolt?
Where I can get a winch handle or make one? Is a manual available? Where to get a new winch strap?
Thanks in advance
Problem1
Problem 2
Thanks in advance
