Trailer Compatibility
C
Calvin
I may try to use a trailer designed for a Catalina 250 to transport a Hunter 26. This would be over a distance of about 125 miles. Can anyone give me advice on this or tell me I am a !!!! fool for trying it. Thanks.
C
Crazy Dave Condon
I would not try it
The bunk board configuration is different and you could seriously indent your hull if the supports for the bunk boards are welded on. Also, the bunks for a 250 are lower and putting a 26 on would put too much weight on the centerboard and you could do some serious damage. If the stalks or supports are adjustable, then probably you could if you are able to determine the height for the bunk boards and configure the hull to the bunk boards. Again if the supports are welded into place say like on Load Rite, the answer is no. I am a dealer and know both boats well. Crazy Dave Condon
C
Calvin
Thanks
I wanted to hear from someone with specfic knowledge and I have. Thanks. Back to the drawing board. How much does a trailer for a H26 cost anyway?
