The boat is about 8 inches short of properly being seated. The bowl does not sit in the front I guess you would call bunks that are on the trailer. My trailer has a long rubber piece that the bowl of the boat sits in. I could not get it to go forward the extra 8 inches, it would not slide. The boat has a great deal of weight on a board that is in the center of the trailer that the keel sits on. The bunks were soaking wet as I had literally buried the trailer in the water. It was in so far that my tailpipe on my Mountaineer was just out of the water. My mountaineer is a 4x4 that sites pretty high off the ground. Knowing the problem I had the trailer worked on. It has a 5 foot tung extension and I had it out as far as it could go. I went on line and nosed around and found a company that made an extension for the extension. I went to a welder and had my version of the extension for the extension made so I could pull it apart and only have the original extension used to the trailer when I was trailering the boat long distances. I went and took my boat pole and marked it off in 1 ft increments to see if this idea would work as far as depth of water and distance that I could bury the trailer. I think it will but have not had a chance to try it. The problem is lining the thing up to the ramp with the nine foot extension on. It should be a blast. The real problem is that I have to float the boat on and off, or I have to have a way to get it on the trailer and have the ability to wench it the rest of the way. If I could just get it to slide my problem would be solved. Because it is not exactly on the trailer the balance point is all screwed up and it is back heavy. WHen I released the coupler the front of the trailer went straight up in the air fortunately I had 2 spare tires up the back so the boat did not bounce off the ground. As they say a boat is big hole that you soak money. The bunks and the bottom board both are covered with carpet. :cry:
TE=Bob Poff;730961]Can you describe what you mean by:"It is on it but not correctly" ?
I don't know about the H23 trailer, but on my old Mac 22 when I replaced the trailer bunks I used a pair of 2x8's. Counter drilled the bolt holes so the heads were below the sufface.
As to friction, usually the boats I've been around didn't slide worth a hoot on a dry trailer. In fact, doing that can leave dents in the hull. Best to move the boat while the bunk covers (mine were like outdoor carpet) are wet. The normal trick to get the boat to move completely up into the bow chock is to pull forward up to about 5-10 mph and stomp on the brakes. And hope it goes in, not to the side.
Seems, not matter how tight I thought the winch cable was, the Mac always settled back a bit.[/QUOTE]
