Tonight I was out working on the boat in the backyard when I looked under the hull and noticed that I found where the missing bolt went on the trailer bunk support - it had come out and was wedged between the bunk wood and the hull. I saw that the hull had a slight indentation from the bolt wedged in there. The last time I used the boat was about a month ago, the first time I have been out on it since I got it in late February (it's been a miserable winter/spring here in Seattle).Basically I freaked out, and figured that I need to get this off the trailer immediately so I towed it to the lake, launched it, then pulled the trailer out to fix it. (See link)I figure fiberglass is pretty flexible to a point, but I still think I see a bit of an indentation in the hull. I didn't see anything under the seat inside the cabin, no cracks or anything bad looking. Could this eventually pop back out or have I completely screwed something up badly?Also, I have my usual problem of getting the boat centered on the trailer. Even when I get the bow all the way up into the rubber v-cradle thing, once I pull it out, I end up with a gap. Maybe I just need to go deeper with the extension? I just have to keep going back and forth trying to get it centered on the keel support, this can be a problem when things get busy this summer at the ramp!What the heck am I doing wrong? I'm new at this sized boat ownership. Launching is easy but picking the thing up is pretty stressful. Also, the winch loop on the boat is always much lower than the winch strap, so it digs into the rubber thing when winching. I'm doing something really stupid I think. I feel that I'm going to really break something in the learning process. Help!(web link goes to some photos I took of my problems.)http://home.comcast.net/~tegwilym/boathull/TomCatalina 22 - 1971 #880
