I was surfing the web and came across a article "Notes on Retrieving"written about a Santana '22. The sailor was commenting on retrievinghis boat onto the trailer and the last couple of feet of winching. Thenhe found a miracle.  From Overton's he picked up some teflon-impregnatedplastic strips that are screwed down on the carpeted bunks.From the article, "As usual, the boat came up about 6 inches short of the bow stop when I pulled it out onto level ground. I got out and began turning the winch handle and absolutely could not believe what I was seeing. All 3000 lbs of boat (with water) was sliding along effortlesslyon the bunks."The full article can be found at ->http://www.trailersailor.com/widget/santana/Retrievi.htmNow, has anyone else tried this? Have you seen It? Does it work?Jim
