The boat trailer I have, I believe is the orginal 1993 Hunter.It is single axel with no brakes.
The port side of tire keeps throwing grease out onto the wheel. There is no grease on the back side of this wheel.
The starboard side has no problem.
The way I understand it the bearing is only located on the back side. So the cap on the front must be allowing the grease leak?
Has anyone had simular problem? Thank you in advance.
Also question number 2....How can I find out what size bearings/ buddie caps should I buy? My bearing cap on front of wheel does not screw in.It is just driven on with mallet.
