My 1995 H23.5 has the factory trailer. When the trailer is empty, I can just barely lift the tongue (I'm not strong). With the boat on the trailer (right up to the rubber block on winch stand) and with the Honda 9.9 still on the transom (about 115lbs), I can lift it easily. With the engine off, I can still lift it easier than when the trailer is empty.
It feels like maybe 70 pounds with the engine, 120 lbs without the engine, and 160 lbs for the empty trailer.
Clearly, the center of gravity of the boat is behind the axle!
I did have the axle replaced when I bought the boat. Could they have moved it forward? I hadn't thought of looking, and now, 7 years later, I might not be able to tell. The boat is 90 minutes away so I can't check.
If I'm doing the math right, I'd have to move the axle back 17 inches to add 200 pounds to the tongue. That doesn't seem right. There's no way they could have moved the axle very far or the wheels would not fit in the wheel wells.
It's 213 inches from the axle to the hitch. To get 200 more pounds at the hitch:
(213 in)(200lbs) = (2500lbs)(x)
17 in = x
I'm guessing the boat is 2500 lbs. After I had the axle replaced, I drove the rear wheels onto a truck weigh station while still attached to the hitch (but the truck rear wheels off the scale) and it read 3300 lbs (without the outboard, and pretty empty because I had just bought it and was only half way home when a bearing disintegrated).
I can't believe the 17 inches. I think the math is right, but I haven't factored in the weight of the trailer itself. That would certainly contribute if you moved the axle, but I don't know how much.
To check the math, lets say the engine is 8 feet behind the axle (I didn't measure but estimated it from some web pictures below). What difference at the tongue does the 115lb engine make 96 in behind the axle?
(96 in)(115lb) = (213 in) (x)
52 lbs = x
That's close. I said it feels like 120 lbs with the engine off, and 70lbs with the engine on, and that's 50 lbs difference. The empty trailer feels like 160 lbs. If I stand on the swim ladder with the engine on, the trailer jack almost floats off the ground. I weigh 155 lbs.
(96 in)(155lbs) = (213)(x)
70 lbs = x
which means with my estimate of 70 lbs to lift it there would now be no weight at the tongue and the jack stand lifts off the ground. So, this math does seem to work.
Looking at web pictures of 23.5's on trailers, the axle is always pretty well under the little aft window. I'm guessing my axle couldn't be out more than an inch or two.
http://www.timshel.ca/lake/pics/wl-1.jpg (Mine, but at an angle)
http://www.buyusedboatsforsale.com/uploads/medium/25596-sailboats.jpeg (random web picture)
17 in = x
52 lbs = x
70 lbs = x
