Trailer axles
Jim Homet
The axles on our '94 23.5 trailer look in bad shape. I'd like to reaplce the axles, springs and hubs before the season starts. Does anyone know of a good place to get replacement parts for the hunter trailers?
Rick Webb
Not in Your Neck of the Woods, But Worth a Look
http://www.championtrailers.com/
Jonathan Costello
Ditto
From discussions with people and looking at Champion Trailer's catalog they make a quality product. I plan on redoing my axle, suspension and brake system and will be purchasing everything from them. Of course it doesn't hurt that I am only 2 1/2 hours away from them. Their axles are hot dip galvanized AND sealed so no water can get inside and rust it out from the inside. The hubs are welded to the axle which is a potential point for corrosion but when it is still hot from the welding they spray it with cold galvanizing compound which helps prevent corrosion. (not as good as hot dipped but still good). They now stock a coated leaf spring that is not on their website. The springs are coated with an anti-corrosion protectant rather than just painted steel. Good Luck.
Jim Homet
Thanks
thanks guys- I'll try Champion. Sorry for the delayed response -I was out of town for a few days. Jim
Rick Webb
You Can Have My Old One
It looks bad but is straight and seems to be solid. Just Come on down and get it.
