Hopefully someone can help me here. I have a vintage (97) Trace 2500W inverter/charger that I use for my house bank. It consists of four 6V wired in series/parallel.
So I have a lucky biz overnight and go to check on the boat. I look at digital readout panel for inverter and the error light is on. Also, the shore power present light is NOT lit like normal. Batteries are flagged only showing 6.5 volts. I run fridge full time so this explains the draw.
Things I did, which I had limited time.
All done with voltmeter.
Checked shore power at box and at plugin to boat. The receptacle actually didnt look so good to went and got a new one. Replaced.
Go to inverter which is first stop after shore power receptacle. 110 going into inverter. Status panel on inverter shows red light. It is hard to tell but the panel has overtemp, undervolt, surge, low battery.
I disconnect all power and shut down boat completely.
I disconnect AC into inverter and also unplug lead out of inverter which runs to status panel. Wait a few then hook back up.
No luck. Error light still on with same symptoms.
I then shut down again and disconnect AC out to panel hoping maybe transfer switch is stuck. But still no luck.
Did the inverter die? Could it possible be protecting itself because of low state of house bank charge?
Thoughts? Time for a new inverter? Its on the right in the pic.
My workaround because I had to leave boat was to disconnect AC to and from inverter and hook together so I can take it out of the loop running power straight to panel so I can use the guest charger and my engine bank to power bildge systems etc. At least she is in the slip safe.
