TP-10 Protective Sleeve
May 23, 2004
3,319
I have a Simrad Tiller Pilot TP-10. I have been thinking about how water may effect it, especially on a rainy day.
Has anyone ever made a sleeve that covers the TP-10 or similar tiller pilot to protect it from the weather?
The other thought is: Is a sleeve really necessary for the TP-10?
I am just curious what other people's experiences are when it comes to this.
Mar 20, 2012
3,983
as advertised by the manufacture, the units are water resistant, NOT waterproof, and yep I have made a cover for mine....
take a piece canvas top window plastic and sew it into a tube that slides over the TP.... then sew one end shut and cut a 3/4" hole in it for the rod to stick out.
then trim the excess plastic at the sewn joints and turn it all inside out so the seams are inside.....
then cut a hole in the right spot near the open end for the anchor pin to stick thru... install it and never worry about the rain.
on mine, where the seam is along the bottom, I took a paper hole punch and added holes about evey 1.5", so any water that may get in due to the wind, will run out, and to add ventilation so it can either help keep it dry or help keep it cool when the sun comes out.
Likes: Bad Obsession
Hey Bad
You had asked me about three weeks ago, if I had installed my TP-10 yet. NO.... but I have acquired all of the parts and I'm waiting for the confluence of a sunny day & a day off of work. I'll post pics and part numbers once I have it working.
r
May 23, 2004
3,319
I have some old Sunbrella and I was thinking about using that and putting a window in it made of vinyl. The problem is that I need a really small piece of vinyl and I don't feel like buying a while sheet to do this.
It seems like a good idea and a little more insurance. I will probably fabricate one this spring because I love having the autopilot on and hiding under the canvas as a lookout when it rains.
Yep, it only took one person to convince me to do this but I was already on this thought process. It makes sense.
I am surprised that no one makes these.
May 8, 2011
189
ODay 25 Cambridge
Cut a small hole in a 1 lb or 2 lb ziploc bag and slip over the arm and cover the unit. Inexpensive and effective.
Mar 20, 2012
3,983
you can buy "window" vinyl at wal-mart in the sewing section... as much or as little as you need..
Beneteau 323 Annapolis MD
[QUOTE....A friend of mine uses a veterinary glove- sticks the ram through the middle finger:) Seriously[/QUOTE]
Yeah, you can get used ones out of the trash: )
May 23, 2004
3,319
Seriously, Walmart has window material? I have never seen it there in my Walmarts. I will have to look again.
I was going to try with the guy who is working on my main sail and see if he will sell me a scrap piece.
Some WalMarts have sewing supplies for cloths etc. and some do not. But you can order on-line through walmart.com
Ward H
Nov 7, 2011
3,774
I only remember I need to do this when I get caught in the rain or a lot of spray. Then I am looking for a plastic bag or cushion to put over it. Had always planned on using Sunbrella and window vinyl.
I just added it to my spring to do list.
May 4, 2005
4,062
fwiw, I had a simrad TP10, and didn't know it was NOT WATERPROOF.
I left it connected on many overnights, where almost everything was wet from humidity in the morning. (needed to wipe down seats, etc)
I never had an issue with the AP. but I didn't see much rain either.
Mar 20, 2012
3,983
i THINK they are intended to be built to take a pretty good shower, but I KNOW they arent waterproof, as this is in the manual... and sometimes even good intentions are not quite enough.
this is an easy out for the manufacture in the event of water intrusion..... and as good and dependable as these newer units are, there is a history of them being damaged by water intrusion.
May 23, 2004
3,319
I am not far from MD, just across the Potomac.
I am picking up my sail tomorrow from the sailmaker and he said he had a few scraps. I will get a scrap from him.
Thanks for the offers and the information.
