Ford Windstar Towing Weight
Marcus,Maybe this will help. Mac 26X - empty 2250 lbs. Trailer - 710 lbs.(Without Surge Brakes) 720 lbs.(With Surge Brakes)Outboard Engine - Depends on size. 50HP 4 stroke Approximately 200 lbs.Take in account, weight of fuel, and water you may carry, as well as gear, and any other thingsthat will add to that. Depending on Model of Windstar, Curb weight can range from 3546 up to 4270 lbs. I am assumingthat you have the 3.8 litre V6. It is rated at 200 HP and torque at 240 foot lbs. with the four speed automatic overdrive. Except for the Basic and Cargo models (rated lower in towing capacity) all others in the Windstar class are rated at 3500 lbs.. Maximum towing capacity. Check your owners manual, and it will tell you that towing while in overdrive is not recommended. There is more torque available (power), out of overdrive. There should be a button on the end of the gearshift lever, push in and a light should come on telling you that the vehicle is out of overdrive. Overdrive is designed for less wear and tear on the engine and drivetrain, as well as fuel economy, since the engine turns over more slowly in overdrive.While your vehicle may pull the Mac 26X okay, in the long run a standard size truck is much better suited for this chore. I have towed my Mac 26X with a 1986 Chev Van with the 4.3 litre V6 engine, and it did okay. Just a little slow on hills. I had a 95 Ford XL 4X4 Super Cab with a 5.0 V8, but it didn't pull as well, and consumed twice the amount of fuel in the process. I traded it off for a 2001 Chev Silverado with the 4.8 litre V8 rated at 270HP. It does a much better job, and isn't as hungry for fuel.Fair winds, and smooth sailing.
