Most vehicle manufacturers recommend that an automatic transmission should not be put in drive/overdrive when towing, because it could be damaged. Instead, they say you should put the transmission in the next highest gear (usually "3") to prevent the torque converter from locking up. From personal experience, this limits highway speed to about 60 mph. Also, because the transmission will be turning at higher revs, they also recommend adding a transmission cooler to prevent the fluid from overheating and breaking down.That's all well and good, but every day I see literally hundreds of vans and pickups hauling all kinds of trailers (including large powerboats) on the highways at 70 mph+. I know they're in top gear and I doubt they all have transmission coolers. I'm planning to start trailering long distances pretty soon (H23 Nationals next year?) and I'm curious as to what the deal really is. For the record, my trailer is about 2800 lb fully loaded and my tow vehicle is a Chevy Tahoe. Any comments?PeterH23 "Raven"
