Towing
Once you spend a few minutes getting the data together, you'll be better able to answer your own question. Most cars can tow just about anything given the right circumstances. It's the stopping, fried transmissions and broken suspensions that you have to worry about. An often cited rule of thumb is that the load should be no more than 75% of the Gross Trailer Weight Rating of the tow vehicle. To be more precise you need to know the following: 1. Actual weight of the boat -- don't rely on dealer/manufacturer dry weight, insist on an actual weighing at a commercial scale before sealing the deal. Or, failing that, add 20% to any figure the dealer/PO gives you.Check your owners manual for the following:2. Weight capacity of vehicle alone: (Gross Vehicle Weight Rating (GVWR)). 3. Towing capacity of the vehicle ((Gross Trailer Weight Rating(GTWR)). 4. Combined weight capacity of vehicle and boat/trailer. (Gross Combined Weight Rating (GCWR)). This is the most important number. 5. Weight capacity of trailer (Gross Trailer Weight (GTW). 6. Tongue weight of the loaded trailer (Should be around 10% of total load).The towing capacity of the Odyssey varies. If it does not have the trailer towing package (trans cooler, suspension upgrades, class III trailer hitch/wiring), you may be able to increase towing capacity by adding these things cheaper than replacing the vehicle. Some dealers can help you with these items but I've found the best source of advice is usually a RV dealer.Or, you could just wing it and rely on what others say you can get away with.
