Use of bridel very important
Just to backup JC's comment about using both side eyelets on the dinghy to rig a bridel.More than once, the line to one of the eyelets either broke or came loose from my dinghy while under tow. Had I not rigged a bridel, both dinghy and motor would have been lost. For stormy weather, I run another "safety" line, just in case the main painter breaks free.Also, there's a major difference towing the dinghy without the motor. With the motor attached, the drag is considerably greater.Even with the motor locked in its up position, when the dinghy's bow rides the wake its stern dips down and the prop still hits the water, which increases the drag.If I'm motoring across the harbor, I leave the motor on the dinghy. Any longer trip, and off it comes.Here's another tip for inflateable dinghys...During periods of heavy rains or very strong winds I pull the drain plug. Lots of rain can fill the dinghy well above its waterline. By pulling the plug, I never get more than an inch or two inside the dinghy. Any additional water self-drains. Of course, you have to be confident your inflateable sections won't deflate.During one very strong wind storm, I watched my dinghy lift right off the water, twirl around, then drop back down, upside down, with the motor submerged. Not good. On another occassion, the waves were so high, the dinghy flipped over, end to end. If very strong winds are approaching, I try to remove the motor. Either way, I half-fill the dinghy with water to keep it right-side-up. Just pulling the drain plug is often enough, as the two inches of water may keep it down. I just worry that if it's being tossed too high this water weight will drain out.There have been a couple of occassions when I half-filled my dinghy with water to give me a more stable trip during very rough weather. Not the ideal situation, but sometimes you gott'a do what ya gott'a do.
