Torque On Keel Bolts for Cat. 32
Dave
I own a 1996 Catalina 32. Can anyone tell me what the torque should be on the keel bolts? I have developed a "catalina smile" and need to check the bolts before I fix the crack.
Peter
Try the factory - we Cat owners can say that!
I called and e-mailed them re: the same issue on my '74 Cat 27, and they gave me the original specs. A lot of boat owners don't have this resource.
John
Torque spec
My C 30 had 1" keel bolts and they needed 100 f/p of torque Nora from C/Y told me that there was no need to reach 100 lbs as long as they where the same torque I reached about 92 lbs and started runing the bolts down from the center in a X patern like tire lugs you should use some 4200 under the washers and aroung the keel bolts to stop water from leaking from the bilge into the wooden keelstub .I would not worry about the torque on the bolts I would watch the glass around the bolts for stress and sinking. The wood around some of the bolts mite be rotten.I replaced my keel stub last year when i cut it out it was looking ok ,it was wet but only a few bolts had rotted to the point of not holding the bolt pressurer . my keelstub was a teak board 1 1/2" thick and very storng when wet.Some of the early catalina keelstubs where made of plywood and when wet they turn to a nasty goooo. John
Jan 31, 2006
4
- - Meyers Point, Cayuga Lake
Thanks for your help. This is a great resource and I hope I can help someone sometime.
