Joel
Well, it's been about a week since anyone talked about topping lifts again. I have read through the archives and seen all the various suggestions.On my boat, the former owner had just replaced the topping lift line. There is no line or cable going through the boom and I have not yet been able to reach him to see how he used to attach the line from the mast to the boom.For now, I have merely looped the line through the end of the boom and snugged it up with a rolling hitch. Since the end of the boom where I have looped it is not designed to have a line tied to it (it's a little sharp for my taste). (The end of the boom has 3 small pulley wheels where the lines are supposed to traverse. Since the topping lift line is not in the boom, I put the topping lift line from the mast through the pulley hole and back up around the end of the mast.Since this is the first year I will be sailing the H23, I want to make as few changes as possible until I learn the boat better.Ron from MPLS suggested attaching two snap hooks to the end of the topping lift and a small loop of line at the end of the boom. Any problems with the hooks snagging on the sail when underway? How did you attach the loop to the end of the boom? Are the jaws at the mast end of the boom truly that "useless"? I could use it as it was designed by snaking a line (good luck) and attaching that to the topping lift. Final question. Where do the rest of you attach the main halyard when not using the main. Again, there's not much at the end of the boom to hook onto. I suppose if I take the "Ron Loop Tooping Lift" approach, I can attache the halyard to that loop as well but that would seem to be a single point of failure. (If the loop broke, neither the topping lift or the main halyard would be attached.
