Flexible thoughts from a rigid mind,
My contention regarding the topping lift was to dispute that its sole purpose is to hold the boom up when not sailing. One poster stated he could think of no other purpose for the device and it should be disconnected when sailing. Another stated that it was only a safety device with no other purpose. Based on my own experience and some casual research I felt compelled to offer another function for the topping lift that some folks might not have considered and I provided a reference link to a sail trim guide that suggested what I had in mind. I have included the link....refer to the section on leech tension.http://www.uksailmakers.com/encyclopedia/encyclopedia5a.htmlWhatever the topping lift may have first been designed for is not the issue. The fact that it is not specifically mentioned as a sail control in most trim guides is not the issue, either. The point is that in light air conditions one can reduce the effects of boom weight on leech tension by tightening the topping lift. This is the issue I offered for consideration. This is why I deemed it a sail control (option).Now.... some folks agreed with my suggestion, othere were quite rigid in their denial. And one self-appointed mediator felt compelled to award points, suggesting a metaphorical TIE between all opinions expressed in the thread, which amounts to a non-position, I guess.Hey,listen gentlemen, I'm very open minded when it comes to new ideas in sailing, or anything else for that matter. Call me what you will but rigid thinking I'm not. Let me ask this question: If you're hammering a nail with the back of an axe, or even the heel of your shoe or a rock .... aren't you still hammering? Are you open-minded enough to consider the idea that the job defines the tool, the tool doesn't define the job. A pen knife becomes a screwdriver when it's used as such, even though it is originally designed for something else. There are many items on a sailboat that can be used for multiple purposes. For instance, a topping lift, boom and mainsheet tackle can be used as a crane to haul in a dingy or lift someone out of the water. Is it still a topping lift, yes, is it also a crane guy, yes. Why, the other day someone posted a link to a whisker pole article, and I learned that the lazy sheet can act as a foreguy for the pole if it's hooked around a bow cleat and led aft. It was also suggested that the lazy sheet is used by some as a barber hauler, under certain conditions. Certainly not mentioned in any of the traditional sail trim guides or history books, but interesting, new ideas for me, to be considered and perhaps even implemented. It is a characteristic of the experienced sailor to be innovative in solving problems. One of the main functions of this forum, other than having meaningless discussions on theoretical hull speed, is to interchange ideas and explore alternative ways to solve boating problems. It is with this spirit I desire to contribute.
