Topping Lift -vs- Ridgid Vang
Oct 25, 2008
168
Albin Marin Vega Bogue Chitto, Miss
Does a "Ridgid Boom Vang" replace a topping lift?
Is the topping lift used when sailing or just to support the boom while
at rest?
In other words does the main halyard serve as the topping lift at the
dock, and then get moved forward to hoist the mainsail, and does the
leech tension of the mainsail support the aft end of the boom
exclusively while the main is up or is the topping lift still in use?
Oct 31, 2019
303
The rigid vangs I have seen and used replace the topping lift as they do
support the boom. I use the really simple Boom Kicker that I inherited with
the boat. I have used the Selden and Hall (these are more complicated at
they have springs and/or pistons in the housing). However attaching the main
halyard to the boom when moored is a good idea anyway, I think. I generally
take some of the load off the vang with the halyard. Then I tighten the
sheet enough to stop things from moving. I generally push the car to the
side away from the dock.
Normally the topping lift isn't used when sailing as the sail supports the
boom. It is really the entire sail that support the boom, not just the
leech, but I am splitting hairs here a bit.
The topping lift can disrupt the sail design if it is tensioned while
sailing. However sometimes you might want that. There are a few occasions in
light airs that some folks might use a topping lift to shape the main a
little. But the Rigid Vang can do that too as they can lift the boom to add
"fullness" to the sail for light air sailing. I do believe the topping lift
is best removed totally when sailing (thus the main halyard is a good
topping lift at the dock if you have a rigid vang). Some are just slacked
but they flop around. Over time, particularly on a long crossing, they can
cause a little chafe on the leech of the sail.
Chris
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf
Of mageekenneth
Sent: Saturday, October 25, 2008 5:17 AM
To: AlbinVega@yahoogroups.com
Subject: [AlbinVega] Topping Lift -vs- Ridgid Vang
at rest?
Oct 19, 2019
921
Albin Vega 27 Limerick
Hi.
I usually sail singlehanded and do not have reefing lines or halyards led
to cockpit.
When it gets breezy and I want to reef asap I find it makes life easier to
1 dump the main sheet and the kicker/vang
2 then ease halyard and clip snapshackle attached to gooseneck to strop
with D ring at each end running through the reefing cringle
3 then harden up halyard
4 then "scandalise" the main by heaving up the topping lift.
This allows step 5
5 outhaul the shortened sail
to be done much more easily as otherwise outhauling the shortened sail
effectively involves lifting the boom!
I have a simple slab reefing system so the reefing (outhaul) lines just go
from end of boom up to cringle on leach of sail, back to turning block on
boom then forward through fairleads to cleats on boom.
If the lines came back to a coachroof winch perhaps scandalising the main
wouldnt be necessary.
So imo the above is the advantage of having a regular topping lift.
I'd be very interested in comments
John
V1447 BreakawayJohn A. Kinsella Ph: +353-61-202148 (Direct)
+353-61-333644 x 2148 (Switch)
Mathematics Dept. e-mail: John.Kinsella@...
University of Limerick FAX: +353-61-334927
IRELAND Web: John Kinsella's Website
Oct 31, 2019
163
Does a "Ridgid Boom Vang" replace a topping lift? No.
Is the topping lift used when sailing No.
or just to support the boom while at rest? Yes
In other words does the main halyard serve as the topping lift at the dock, and then get moved forward to hoist the mainsail No, they're seperate pieces of string; the main halyard is connected to the head of the sail and pulled tight, so raising the mainsail, at which point the topping lift is slackened off and left loose whilst sailing.
and does the leech tension of the mainsail support the aft end of the boom
exclusively while the main is up Yes
or is the topping lift still in use? No left loose (see above)
Whilst either a vang or a topping lift will both hold up the boom, when the mainsail's not raised, they do very different jobs once it is. At this point the topping lift should be loosened off as described above and doesn't generally do anything at all (other than make an irritating slap-slap-slap noise against the sail in certain wind conditions) until you re-tension it prior to dropping the sail once again. The vang meanwhile now commences doing its primary function, which is to hold the boom DOWN; without it or the more usual/standard kicking strap fitted, the boom will have a tendency to lift when the wind's blowing from abaft the beam, thereby scandalising (a fancy name for making baggy) the main sail and so losing power.
Hope this helps
Bob Carlisle
Spring Fever 1776.
Oct 31, 2019
303
As before, I both agree and disagree (again there are many different ways to turn one’s crank – not necessarily wrong, just different)
On my last five boats I have used a rigid vang and didn’t use a topping lift (although on a couple I actually had the gear already on the boat, but didn’t use it). I agree the primary function of any vang is to keep the boom from lifting when sailing down wind -- the sheeting angle of the main sheet exerts less downward pressure because of the oblique angle when the boom is out from center. A rigid vang has an addition job however and that is to support, and even lift, the boom (or why else go to a rigid vang anyway as they are pricey). Most rigid vangs will lift the boom some, I suppose all will if installed properly.
That brings up another point, most rigid vangs aren’t just a rigid piece of tubing. They have some spring in them. Some have a pneumatic cylinder and some actual springs (or the one I use is just fiberglass tubes that are bent under pressure). Thus, when buying a rigid vang it is necessary to calculate the amount of upward tension needed along with the size of the device. Many vangs allow different spring tensions to be installed in the same size unit.
When my main is down I do attach my halyard to the boom’s end and put some upward lift to it. Not much, just some. Not that I have to, but why not since the halyard is just hanging around not doing much anyway. While this is not a topping lift by definition, in this instance it is doing what a topping lift would be doing at anchor. By the way, on many of the big boats I’ve raced on, or used to race on, we’d often take the topping lift totally off even if we didn’t have a rigid vang or before they existed (the rigid vang is a rather new invention in the history of sail).
There is no reason not to have a topping lift with a rigid vang other than the thing flapping around and slapping on the sail. When one has full battens and an extended roach it can get rather annoying. As was said, you don’t want tension on the topping lift since the sail holds the boom up, while the sheet and vang hold the boom down – thus allowing proper sail shape to be accomplished.
As with many things in sailing there are many ways to accomplish the same thing and none are inherently wrong. The best example I can think of is just to walk down a dock and marvel at all the different types of anchor and anchor gear – all to accomplish the same basic thing.
From: AlbinVega@yahoogroups.com [mailto:AlbinVega@yahoogroups.com] On Behalf Of Bob Carlisle
Sent: Sunday, October 26, 2008 1:05 PM
Subject: Re: [AlbinVega] Topping Lift -vs- Ridgid Vang
In other words does the main halyard serve as the topping lift at the dock, and then get moved forward to hoist the mainsail No, they\'re seperate pieces of string; the main halyard is connected to the head of the sail and pulled tight, so raising the mainsail, at which point the topping lift is slackened off and left loose whilst sailing.
Whilst either a vang or a topping lift will both hold up the boom, when the mainsail\'s not raised, they do very different jobs once it is. At this point the topping lift should be loosened off as described above and doesn\'t generally do anything at all (other than make an irritating slap-slap-slap noise against the sail in certain wind conditions) until you re-tension it prior to dropping the sail once again. The vang meanwhile now commences doing its primary function, which is to hold the boom DOWN; without it or the more usual/standard kicking strap fitted, the boom will have a tendency to lift when the wind\'s blowing from abaft the beam, thereby scandalising (a fancy name for making baggy) the main sail and so losing power.
Hope this helps
Bob Carlisle
Spring Fever 1776.
