Topping Lift and Sail Shape
I'm no expert, but I will weigh in with an opinion on the original post question.I suppose that the topping lift could theoretically help to hold some basic sail shape when sailing in light winds, but there is a little bit of a practical problem with that.Supporting the position that it might work is the idea that you frequently have crew sit on the lee side of the boat in light winds to add a little heal to the boat, and to cause the sails to hang closer to the position that you want them in when there is some wind. The explanation I was given was that doing that allows the little bit of wind there might be to start working with the sail right away rather than being wasted in putting that basic shape into the sail.Using a topping lift to keep the weight of the boom from pulling the desired shape out of the sail - by weighting down the leach of the sail, sounds like a good idea, but when you tension that topping lift, you'll also be interfering with the little bit of overlap that the leach of the main has with the topping lift, and that will goof up the shape even more.I think what I see being used more and more is a rigid boom vang. It takes care of a couple of jobs on the boat. It provide the traditional Vang function of hauling the boom down to affect the mainsail shape. When the Vang line is loosened, it also serves to support the boom (taking the place of the topping lift) and in light winds, adjusting the vang way off, the spring inside the rigid vang can hold the boom - and the sail shape - just where you want it.Good Luck!Tim BroganApril IV C350 #68Seattle
