Mark
Hi,We are buying a 1996 29.5. Previous owner has demonstrated to us that it is necessary to significantly loosen up the topping lift while under sail; otherwise the leech of the main will be restricted by the topping lift line when we tack, (because of the overlap and battens). He also let us know the consequences of the boom dropping onto his crew when he has forgotten to reattach the line before dropping the mainsail... While it's not such a big deal, I was still wondering if anyone has found a different solution so that this is not necessary to bother with. (I will be sailing with a non-sailor wife and 3 small children, so I am trying to keep things safe and simple. )Thank you.
