Topping Lift - 28.5
C
Cappy
My topping lift line is separating. Other than replace the topping lift, anyone have any comments on alternatives, such as boom supports, Boomkickers, rigid boom vangs on 28.5's? I had a Boomkicker on a 26' prior, seemed to work as well. Thanks in advance!!!!
Tom
Check out Garhauer Marine Hardware
They make a great rigid boom vang that will allow you to remove your topping lift... and good ridance! Fair winds, Tom
Bill O'Donovan
However...
Topping lift is inexpensive and effective. Simply attach 2 bitter ends together to re-do. For gizom sake, you could always attach a small 4-1 purchase as used on racers to raise and lower the boom from the well. Lot easier than a rigid boom vang, which is overkill.
