Top Motoring speed for Oceanis 390
Jan 16, 2013
17
Catalina C400 MKI St Joseph
Would like some ideas of how fast people can motor at what RPM. I have a Volvopenta 2003T 43 hp built in 1991 with a Autoprop
May 7, 2014
135
Beneteau 390 Tiburon
Ron I didn't mention I have a fixed three blade prop and with a clean bottom it moves at a good pace. Thanks for your help
May 13, 2013
42
Beneteau Sense 50 San diego
In general, you should be able to motor at 1.2 times the square root of waterline length. At hull speed you use too much fuel. If your boat is the 39 that has a waterline length of 33.25 feet then 6.9 knots in flatish seas is a good rule of thumb. I believe the maximum rpm is 3200. Run your engine at full speed to make sure you get 3200. If not, you are either over propped or underpropped. You should get the 6.9 knots at about 80% or 2600 rpm
