Tool Rental
Aug 16, 2009
1,000
Hunter 1986 H31 California Yacht Marina, Chula Vista, CA
The post about shroud tensioning got me thinking about rarely used tools and wondered if anyone knew of a source for renting such things as a shroud tensioner or a cutlass bearing removal tool. Tensioners cost about $100 and would be used once in 5 years by any given sailor?
7,422
Alden 50 Sarasota, Florida
Tension gauges and bearing pullers are fairly common among those of us who do our own maintenance. A variety of common tools can be used as tension pullers too so I doubt there is any market for rental.
I can't imagine a marina with a service dept which doesn't have these things you could use or rent but I may be wrong as I never tried.
Aug 16, 2009
1,000
I suspect if the boat were hauled out at a boat yard they might let you rent or use their tools, which would be the case for the cutlass bearing. Doubt they would let anyone walk off with a tensioner even if you were willing to leave a deposit. Are you thinking that any tensioner that could measure up to 1000 lbs or so would work?
Oct 17, 2011
2,809
Ericson 29 Southport..
The thing with a tension gauge is you need to know where to stop pulling, and a Loos gauge does that. It wouldn't take nearly a thousand pounds though, a twenty pound fish scale may work. But again, you need to know exactly how FAR to go with the gauge. And I wish I were closer, you could use mine, I certainly don't put my hands on it often..
Aug 16, 2009
1,000
You're right Chris. I was looking at breaking point. The tension is probably around 3-700 lbs. Hunter actually provides the tension figures for the H31 using Loos gauge at http://www.marlow-hunter.com/export...r RF Mast Riggig 2010 Info guide US Spars.pdf.
The Loos PT-1 is for cable up to 5/32 and the PT-2 3/16-1/4. I think the H-31 requires the PT-2. The manual has the wire specs on the forestay, backsay and shrouds.
Maybe someone local will check in and I can rent from them.
Sep 15, 2009
6,243
S2 9.2a Fairhope Al
another nice thing about the loo's gauge is that you can get a balanced cable tension on all your upper and lower side stays ...even if it is off a few lbs will not matter because they will all be the same ...best tool in the bag for the money ....you may pic one up on e bay for about 50 bucks if you watch for it
