I purchased my Albin Vega 2225 Named Sealegs a couple months ago in
Elizabeth city North Carolina. I paid to much for her as I usually do,
but am happy with her anyway.
Well my wife and I got Sealegs up to Deltaville Va. We had a nice
trip but had to motor a lot more than I would have liked. We sailed from
the Elizabeth river at Norfolk up the bay in SW to NW winds from 5 to
20 knots with some gusting to likely 25. We kept a full main but
shortened the jib way down when in areas of higher gusts. I was really
surprised that there was so little difference in the helm with only a
rag of jib still set. The main has full battens I did not use the bottom
batten as it was missing one end cover so I didn't want to damage the
batten pocket.
A few things need repair. The water tank which is steady leaking
around the fittings needs a little teflon tape. Easy to repair! The
gusher builge pump needs a repair kit. The rear engine main leaks a
little when setting, but does not seem to leak when the engine is
running. Looks to be not too hard to replace that seal which I think is
nothing but a standard industrial seal. There are other similar repairs
to be made some of them electrical. The former owner did some
electrical improvements that have to be redone as the wiring is too
light and is not up to speck. He tried!
The topsides need repainting and I will paint the nonskid as glass
is showing through and the nonskid is worn through. The hull sides had
been painted at one time but has since worn through in some places where
fenders have ridden so that will also be redone. This is all work I
can do as I have built several boats and painted them. I have not
found any serious problems. The previous owner did a nice job of
replacing some wood that needed it in the cabin and repainting so she
looks good inside.
My wife is a canvas worker and seamstress so a new dodger is in the
works as well as a Bimini as we are too old to set out in the sun. The
cabin cushions look pretty good but the foam is about shot so she will
redo all that next winter. By Spring of 2011 she should look pretty
nice.
I would like to keep the old engine if I can find rebuilding parts
before time to rebuild. This engine seems good for now. I grew up with
similar engines in boats in the early 1940s. I know of no other two
cylinder engine that runs a quiet and smooth as does that Volvo with
it's big heavy flywheel carrying momentom through between fireings. She
actually has the pleasant sound some akin to a steam engine when setting
in the cockpit listening to run at about 1600 rpms. At rebuilding
time, if I can't find parts I may be able as a machinist to re-babbitt
the bearings and re bore the connecting rods and mains. If need be the
cylinders can be re-bored and some other standard piston might be
used. This all assumes that parts will not be available. I feel she is
a far supiorior engine to any of the newer engines like Yanmar and
Kabota and the other cheaply built motors now available. I would not
hesitate to spend the same amount of money to rebuild my volvo as the
price of a new engine. This engine developes it's horsepower at 2000
rpm where the newer ones develop thier power at 3600 RPM, are hard to
crank and sound and run like they are on their last legs.
I have a really fine and safe place to keep her. She is in a cove
in Jacksons Creek in Deltaville Va. where three sides are closely
protected by land with one side open but there is only about 200 yards
of fetch across the water. A perfect place with us living a couple
hundred miles away. I have friends that live on the creek so they
will check on her in Northeasters when there are very high tides. I of
course will have to do what needs to be done in hurricanes which is have
a nearby marina haul her for really bad storms. I have kept a couple
different boats there about 40 years ago with the present owners
father. The son has allowed the place to run down. I am sure that
when his mother passes on he will build condos there and that will be
the end of that marina. Maybe I will buy a condo if my money ship comes
in.
Douglas Pollard Albin Vega Sealegs 2225
[Non-text portions of this message have been removed]
batten pocket.
looks good inside.
nice.
in.
