I realize these heads are supposed to 'self prime', but my manual Jabsco 29090 will not draw any sea water into the bowl. I've done all the normal stuff...sea cock open, holding tank empty, no kinks in the lines, handle works okay, vented loops okay, etc. Tried closing the sea cock and pumping the handle and it seems there is no suction. The pump assembly was rebuilt last spring and worked fine all summer. If I dump water into the bowl from a bucket (or pump it from the sink) it will pump it into the holding tank. It just will not draw it in through the sea water line as it should. Any suggestions would be appreciated. Thanks.
